what clutch do you have?
Old May 11, 2008 | 10:53 PM
richcz28's Avatar
Car: 1984 z28 h.o.
Transmission: 5 speed
There probably is a thread for this somewhere already but it should be stickied. I am trying to decide what clutch brand to use. I heard Borg Warners were good but they dont seem to still be produced? I have a 305 h.o. camaro.
Old May 12, 2008 | 02:05 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what clutch do you have?
McLeod.
http://www.mcleodind.com/
Old May 12, 2008 | 02:23 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i'm using a centerforce dual friction in my car.. its a 385 and the clutch holds just fine.. sometimes too good.. but i did have a problem with it during powershifting..
my theory had it that the weights were making the clutch fingers bend under quick operation making the pedal almost useless for super fast shifting.. i almost always missed a gear while doing this.. after i took off the weights, it works like a charm..
i'll be going to a Ram Powergrip HD after this one goes..
Old May 12, 2008 | 06:52 AM
squeeezer's Avatar
Car: 5 cars
+1
Old May 13, 2008 | 10:07 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I use a stock clutch, maybe 350HP here. It holds better than my tires can, so...
Old May 13, 2008 | 02:04 PM
richcz28's Avatar
Car: 1984 z28 h.o.
you do not use a stock clutch. how many miles does your car have like 15k? most camaros i've heard of especially z28s are on there second by 30-40k miles.
Old May 13, 2008 | 02:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh not stock as in "left michigan with it in there", but stock as in parts store replacement for 1982 Trans-am. Not a high end aftermarket $300+ part. I just paid $70 for the friction disc and threw it in, and used a new TO bearing and I was good to go.
Once I have really sticky tires, and some more HP, i'll be looking at a centerforce dual friction, i've heard good things.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
