Gear ratio question
Old May 16, 2008 | 06:48 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Gear ratio question
I know theres a simple formula to figure out the gear ratio and I cannot seem to figure it out. With one full rotation of the tire, I get approx. 1 3/4 turn of the driveshaft.
Old May 16, 2008 | 07:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Gear ratio question
its a bit more precise if you rotate the tire 5 or 10 times and count the driveshaft. divide the two. exp. 5 spins of the driveshaft divided by 2 spins of the tire is a 2.5 ratio
you need to spin wheel more, from what you give you come up with a 1.75:1 ratio, which is far from, what it is.
keep on spinning
Old Jul 13, 2008 | 04:28 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Alright so I finally got to doing this. So with 5 full rotations of the wheels I only got 8 and 3/4 rotation of the driveshaft... I am very un-happy with my current situation.
Somethings not right. But I counted correctly I am sure of it
Old Jul 26, 2008 | 03:01 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Any thoughts? Another thing...
I know the gear is poor because at 75 mph i am only at 2,500 rpms
Old Jul 27, 2008 | 04:00 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Old Jul 27, 2008 | 04:47 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I've done it 2 ways. For posi rears, just one rotation of the tires should give 2.5-3.5 rotations of the driveshaft; meaning the gear ratio is 2.55:1 up to 3.42:1. It's the same for a non-posi axle, but only let one tire rotate, and make it go 2 rotations.
My guess is that you have a 3.42:1 because that 1.75 is far too close to being half your gear ratio.
Old Jul 27, 2008 | 05:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
at 60mph, are you at 2K rpm? that is where I am with my T5 and 3.42 gears.
Old Jul 27, 2008 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its time you just pull the cover off and count teeth, its not working for you any other way, and im sure the gear oil is in need of changing anyway.
Old Jul 29, 2008 | 05:02 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Yes
Old Jul 29, 2008 | 05:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Save yourself the counting the gear ratio is stamped on the od of the dr gear.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
