9 bolt question, leaking pinion seal
Old May 18, 2008 | 12:03 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Well I just got my 9 bolt back together but when i when to tighten the pinion nut, the yoke does not go in fully to the seal. I have about 3/8" to go before until the yoke is fully seated into the seal. I filled it up with oil anyway and drove around for a bit. sure enough it leaks. What is preventing yoke from fully seating into the seal? do i have the wrong crush sleeve installed?
Old May 21, 2008 | 08:02 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Re: 9 bolt question, leaking pinion seal
well I took the seal off to make sure my yoke was pressing up against the bearing. It does contact the bearing however no matter how hard i tighten the nut I do not get hardly any preload. In fact there is still considerable amount of lateral movement left in the rear bearing despite the nut being super tight. I think I have an incorrect pinion installed. Did they make different length pinions for these rears? Or perhaps I was given a 10bolt pinion by mistake? What else could causing this problem?
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
