Is this a differential leak?
Old May 26, 2008 | 05:36 AM
Jonboy2312's Avatar
Car: 1986 SC based 82-84 Z28 replica
Engine: 2.8 V6 MPFI
Transmission: TH-700R4
Yesterday when installing new wheels, I noticed the RR tire was all greasy on the inside - having drips of some oily fluid all around. There is something leaking from the bottom of the brake drum.
Now, I'm wondering... is it brake fluid, or a differential leak going all the way through the axle?
To make matters worse, the brake line on the other side burst. Well, that's clearly brake fluid - it's spraying it like a fountain. But what's this on the passenger side?
Either way, more expenses...
Old May 26, 2008 | 07:08 AM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: Is this a differential leak?
axle tube seal or brake fluid, is it thick and gooey or real wet? if it's thick it's probably axle seal which isn't hard, just takes a couple hours.
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
usafirebird
Sep 29, 2015 11:58 PM
mfp189
Sep 27, 2015 09:25 AM
