3:73 racing
Old May 28, 2008 | 09:41 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
3:73 racing
Ok when i put the 3:73 posi in how much of difference will it make from my 2:73 non posi?
People have told me when i race a camry or civic or something they would keep up b/c of my gearing well now what will happen?
thanks,
kevin
Old May 28, 2008 | 10:02 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 3:73 racing
The 3.73 compared to the 2.73, you will leave harder off the line, but your fuel economy will dip a little.
Old May 28, 2008 | 10:07 AM
Re: 3:73 racing
I dont care about the gas i just want to make my car faster.
kevin
Old May 28, 2008 | 10:20 AM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: 3:73 racing
Exactly But you also would beable to spin the tires easier, so practice launching without spin and ur off!
Old May 28, 2008 | 10:24 AM
Stephen's Avatar
Car: 87 GTA
Re: 3:73 racing
My wife switched from a 3.08 open to a 3.73 posi....Had to relearn how drive the car in Autocross!
Coming outta the corners, it would come loose MUCH easier.
As for racing r i c e....If you don't blow the tires away on launch, they shouldn't be a proble, on the bottom end. They might on the top end, depending on your car & theirs.
Old May 28, 2008 | 12:03 PM
Re: 3:73 racing
When i race i want a dead stop and as log as a 1/4 mile. I just wanted to make sure that it would make my 1/4 mile time faster.
If i run a 15.7 now what will it make me do with 3:73 posi?
kevin
Old May 28, 2008 | 05:50 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
Re: 3:73 racing
should knock about .3-.5 tenths off, it was deffinately one of the best mods i did to my car, and i still even got over 20 mpg with 3.73s
Old May 28, 2008 | 07:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: 3:73 racing
Night and day difference kind of better - it will feel like you added 50 or 60hp.
Old May 28, 2008 | 07:59 PM
Re: 3:73 racing
Fell like 50 or 60 hp then this is going to be a good mod to start with it sounds like.
kevin
Old May 28, 2008 | 09:49 PM
Air_Adam's Avatar
Re: 3:73 racing
kevin
Gears and exhaust are BY FAR the most important initial mods to any 3rdgen - changing to a better gear ratio makes such a huge 'seat of the pants' difference, most people don't realise just how much different it actually is untill they do it!
Old May 29, 2008 | 09:18 AM
Re: 3:73 racing
Do you think it will make me chirp the tires going into 2nd.
kevin
Old May 29, 2008 | 10:05 AM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Re: 3:73 racing
kevin
Dont count on it with the auto. With a 5-speed it would be no problem.
Old May 29, 2008 | 11:02 AM
Re: 3:73 racing
But how about with a shift kit?
kevin
Old May 29, 2008 | 11:23 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 3:73 racing
kevin
You want faster, for starters get rid of that beast of 305 TBI.
Old May 29, 2008 | 12:04 PM
Re: 3:73 racing
I am around october but i need to build my rear end up b/c i want 480-520 hp to the wheels. I'm just building it up as i go along.
kevin
Old May 29, 2008 | 04:26 PM
TheBigJ's Avatar
Car: 85 Firebird
Re: 3:73 racing
Good start... build from the ground up... next ur trans, look into a 5 speed if you want to chirp. I know you can do it with a auto, you would need some kind of kit (shift, valve body etc) which is easy stuff. I always get the ratio vs chirp mixed up, but a 'chirp' is with the trans... you should work on that later (next inline)
Old May 29, 2008 | 05:38 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: 3:73 racing
I'll say my old 350 w/ 3.23 gears and automatic was WAY slower / sluggish feeling that my new setup (read sig). I'm trying to learn to handle spinning the tires at 30+mph in 2nd and 3rd gear when I mat the gas pedal.
Old May 29, 2008 | 05:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 3:73 racing
me too
on another note, when i swapped my 2:73 to 3:73 in my 10bolt, i swapped in a billet "superior" servo in my old 700r4 with a stock caprice 350 and it would chip the tires in second and third, then put on that funky little sonnax spring and it starts to hurt your neck, and probably the trans/ujoints/ect, but its fun.
Old May 29, 2008 | 06:49 PM
Re: 3:73 racing
Man i cant wait to get mine all done up. How much do you think it will cost for someone to install my gears.
thanks
kevin
Old May 29, 2008 | 06:51 PM
AC's Avatar
AC
Re: 3:73 racing
Just a guess but 200-300 bux.
Old May 29, 2008 | 06:53 PM
Re: 3:73 racing
Ok that was like my guess to thats not to bad i guess.
kevin
Old May 29, 2008 | 07:18 PM
Air_Adam's Avatar
Re: 3:73 racing
kevin
If thats true, then you might be better off saving the money for a 9" or 12-bolt setup... that will eat your 10-bolt (and all that follow it) for lunch.
My car makes probably 300-320rwhp, and I've gone through 3 rear ends in 2 years. It doesn't take much to break them.
Old May 29, 2008 | 07:42 PM
Re: 3:73 racing
wow that sucks, and you only got a little over 300 why is that a bad rear end then?
kevin
Old May 29, 2008 | 08:15 PM
Re: 3:73 racing
The reason i wanted that much hp is b/c i wanted to some alot of them dumb kids on the road with their civics. How much hp do you think i would be happy with? I can get a 383 stroker that an engine shop by me makes and they start at 400 hp so mid 300's to the rear idk if i would be happy with that?
thanks
kevin
Old May 29, 2008 | 08:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 3:73 racing
kevin
the 10 bolt has a small 7.5" ring gear and equally small pinion gear, they are the weak point and are usually the first things to fail. everything about the carrier assembly is small. If you are really planning a healthy motor, save your pennies for a 9" or 12bolt.
thats more up to you to decide. If the car is eventually going to be a weekend/fun car and not a DD, go all out, no matter what you start with you will eventually be looking for more power. Just be prepaired to upgrade the rest of the drivetrain and suspension as well.
Last edited by //<86TA>\\; May 29, 2008 at 08:32 PM. Reason: Automerged Doublepost
Old May 29, 2008 | 09:15 PM
Air_Adam's Avatar
Re: 3:73 racing
kevin
300rwhp... around 370 crank hp. But its not that theres anything mechanically wrong with them, they are just severely underbuilt for cars making that kind of power. They were initially designed for small economy cars, like the chevette, but since the smaller rear end also helped boost fuel economy in the bigger cars too (less drag from the mechanical parts) they also put it in these cars, hoping it would outlast the warranty period. They were fine for the 150hp 305s they came with, but don't hold up well to a motor with any real mojo.
The rear ends are not bad for just driving around, and will take some abuse, but they don't handle really sticky tires or clutch dumping very well... same things that break T5s break these rear ends too, pretty much.
As far as what HP you'd be happy with... thats up to you. But in my experience, most people don't realise how fast a relatively light car like this is with a solid 350hp. Its more than most people really need or will ever use. Drive an LS1 4thgen and you'll see what I'm talking about.
Old May 29, 2008 | 09:19 PM
Re: 3:73 racing
Dose your engine make you happy or would you want more hp?
kevin
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
