Rear end?
Old May 28, 2008 | 08:06 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Rear end?
I recently changed the fluid in my 9 bolt rear end and ever since it has been leaking a pretty decent amount. It seems to be coming from the drain/filler plug. I know i could go buy a new one somewhere im sure but i already have some RTV gasket stuff. Would it be okay to seal up this leak by removing the plug and sealing it with the RTV gasket than putting the plug back in? Or would that harm my rear end in any way/deteriorate the plastic plug and cause more leaking?
Old May 28, 2008 | 09:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Rear end?
Is there supposed to be a plastic gasket on the plug, like the oil pan, that maybe got forgotten or broken?
Old May 28, 2008 | 11:05 PM
Saber's Avatar
Re: Rear end?
Well when i changed it, i took everything apart in a shop and didnt notice anything of that sort, when i took it off or when i put it back in, it seems to fit sung, it was hard to get off and it never leaked before but now its leaking quite a bit. It is a 9 bolt Borg Warner rear end off of an 87 formula, the last time the gear fluid was changed was by the guy i bought my car off of almost 3 years ago, he could have misplaced something of that sort i guess but idk, Is there supposed to be something there? This was my first time changing rear end fluid and i read up quite a bit and i didnt hear any mention of such a gasket that i can remember...
Old May 29, 2008 | 06:35 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rear end?
With these old cars, any fix you can come up with and it works is a good fix. Your idea is OK.....
Old May 29, 2008 | 08:05 AM
Saber's Avatar
Re: Rear end?
Thats what i was thinking, i just wanted to make sure it wouldnt harm anything. Although i did look around and i did not notice any mention of a gasket for this plug so im guessing one doesnt exist.
Old May 29, 2008 | 07:14 PM
Air_Adam's Avatar
Re: Rear end?
If the plug has a flat surface to sit on when its tightened down (I honestly can't remember right now, flatulent brain) then grab a .10 plastic oil pan drain plug gasket that fits the plug and that should do the trick. Using RTV should be ok too though.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
