What Fluid should i Use Please help
Old Jun 6, 2008 | 07:40 PM
StonersTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
Please help me soon. I planned on getting the tranny back into the car this weekend and when i went down to buy fluid the guy behind the counter scared me now. I just had to take out a BRAND new tranny and have it fixed. burned up the clutches...all of them. So he tells me that if i buy the wrong fluid i can burn up the clutches. now im scared that maybe that was the problem all along. I have a Hughes Performance Street and Strip 700R4/ 4l60 I know what a stock 700should use but would it be the same on a Hughes? please help ASAP
Old Jun 6, 2008 | 09:47 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: What Fluid should i Use Please help
Dexron III, you'll be fine
Old Jun 8, 2008 | 11:12 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Dexron. If you havent filled a dry trans. before becareful. Put 5qts in start it up then put in the rest untill full.
Old Jun 12, 2008 | 05:40 PM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
has any one ran B&M's trick shift in a 700r4. It worked well in my old turbo hydros 350 & 400s.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
