got an transmission question....
Car: 82 trans AM 97 Firebird
Engine: 305v8, 3.4v6
Ok, i have just got an 82 trans am it has an 305 in it, the transmission only goes in backup if the car has been warmed up, The guy we got the car from says it needs a transmission flush ok, well does that explain why it doesn't kick into 4rd gear out of 3rd? it's an automatic.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: got an transmission question....
If its a stock '82, then it isn't going into 4th because its only a 3spd trans. The 4spd autos started in '83.
Car: 1985 chevy camaro
Engine: V8 305 5.0
Hi, I have a 1985 Chevrolet Camaro Berlinetta here's a link to see it http://www.cardomain.com/ride/3088924 (it's automatic) and it shifts as smooth as glass but when I put it in reverse and only in reverse it make a clicking noise. It’s not loud but it is noticeable and well what can I do? Is the trans going to give out soon? How long do i have? Please help
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
should be a 3 speed auto. could be low on fuid but I bet the servo is leaking.
We checked the fuid last night it was full, it was not burnt fuid either.
Ok what is the torque arm? i am learning so a photo would help so i won't mess with the wrong thing
Last edited by CamaroFreak2008; Jun 9, 2008 at 05:22 PM. Reason: Automerged Doublepost
If you look under the car, you will see a long stamped steel 'arm' that follows beside the driveshaft, connected to the transmission on one end and the rear axle at the other end. At the transmission, its held in place by a rubber bushing with a clamp on it.
Alright, i will have a look tomorrow.
Make sure the bolts are tight and nothing obviously broken. If that seems ok, then grab the front of the torque arm (trans end is the front) and move it up and down, too see if or how much play/slop there is. There should be none. It should be able to move a little bit, as the mount is rubber, but it should not move around loose inside the bushing (bad explanation of that, I'm sorry, lol).
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
as for the OP are you sure its full of fluid if it is then a flush is not going to help you have a mechanical issue
Check the TA bushing, then the Trans Mount, then the U-joints (in that order IMO). Something is probably up with one of those 3.
