Rear end swap Speedometer question??
Old Jun 6, 2008 | 10:24 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
I am swapping the stock 2:83 searies gear out of my 91 for a G92 3:23 rear. My question is, does anyone know which speedo gear I will need for the trans to make sure the speedo is correct?
Old Jun 7, 2008 | 11:16 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
Re: Rear end swap Speedometer question??
i never thought of that. i just did a similar swap and im not sure if it makes a difference. could someone let us know?
Old Jun 8, 2008 | 01:38 AM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Oh it makes a difference, your speedo will say your going faster than you actually are (not as bad a vice-versa) but I still like it to be correct.
Old Jun 8, 2008 | 12:13 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Try this for calculating the correct gear you need for the speedometer drive.
http://www.hanlonmotorsports.com/t5speedo.asp
And I've been very pleased with the service from this company.
http://www.transmissioncenter.net/sp...#Misc.%20Gears
Old Jun 8, 2008 | 09:36 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Transmission: TH350
Thanks a lot, thats solves everything.
I think those sites should be a sticky on here as well
Old Jun 9, 2008 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by F_N_JUNK
Thanks a lot, thats solves everything. I think those sites should be a sticky on here as well
Both sites are mentioned in the following link; however, since the link is for T-5's, most 700R4 guys won't check it.
https://www.thirdgen.org/forums/tran...ve-driven.html
JamesC
Old Jun 11, 2008 | 07:28 AM
GrayTA's Avatar
Car: 1989 Trans Am
Engine: 5.7 Carbed 1970 Camaro SS Block
Axle/Gears: 2.73, becoming 3.42 Posi
Is it the same for T-5s and 700R4s??
Also, where do you change the speedo teeth? I am changing my rear as well going from a 2.73 to a 3.42. I know I need a brown one, but if I get the brown one where is the place to install it? Inside the dash? I really am clueless on this...read a lot of threads, but havent seen the answer yet.
EDIT: I think I just found it amazingly enough...but how long does it take to do?
PDG
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
