shifter adjustment??
Old Jun 9, 2008 | 12:33 AM
jjskibbs's Avatar
Car: '89 IROC
Engine: 350 TPI 5.7L
Axle/Gears: axle?? got me.. 3.73:1 gears
my gear shifter is not positioned right. when yuo put it in gear it reads between gears. and when putting it in park it doesn't feel like it goes in properly. is there and adjustment for the shifter to line up??
89 305 tpi automatic.
Old Jun 9, 2008 | 03:51 AM
chupalupa's Avatar
Car: 1991 z28
Engine: L98 TPI
Transmission: Built 700R4
Axle/Gears: 3.23 posi
Re: shifter adjustment??
only real adjustment is at the shifter cable connection at the trans.. as i remember theres a right and wrong way to adjust it, i just dont remember which is which right now :P im sure someone knows the procedure tho I thionk most of it is the indicator itself wearing out tho..
Old Jun 9, 2008 | 04:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
or, a common occurrence is the bracket falls off the trans pan. get under the car and check the linkage bracket, its probably come loose, is seems to happen a lot.
Night rider327
Feb 25, 2016 09:50 AM
Reid Fleming
Oct 10, 2015 09:56 PM
AUZ28
Oct 3, 2015 06:28 PM
meeklay812
Oct 1, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
