Look for a couple parts (Where to buy?
Old Jun 12, 2008 | 12:29 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Im looking for the Driveshaft straps. The 2 U shapped braces that hold the DS to the rear end pinion. And Im also looking for the clamshell peice that hold the torque arm to the trans. I did some searching and found the straps for a vette and I donno if its the same size. And I found that the clamshell is discontinued?? Anyone know of a place I cna order these parts from. Thanks
Old Jun 12, 2008 | 06:34 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Look for a couple parts (Where to buy?
The straps are pretty much the same for most GM passenger cars, I think they're available in the HELP section in most parts stores. The clamshell, you may have to hit up a boneyard, or try Hawks.
Old Jun 13, 2008 | 07:27 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
K, I foud a clamshel on ebay Im bidding on. Ill check the parts store over the weekend. Thanks
Old Jun 14, 2008 | 02:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I just ran across some of the straps/bolts the other day (I couldn't find them and had bought new aftermarket ones.) So I know what you mean.
Old Jun 22, 2008 | 03:06 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Ok well I went to Advance auto and got a pair. Bring them home and they arent wide enough to go into both holes. Return those go to NAPA, they got the exact same size! Its a 10 bolt rear so that should be pretty standard I mean its stock. Anyone know wher eI can buy the wider ones online?
Old Jun 24, 2008 | 12:38 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Anyone?
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
MENINBLK
Aug 5, 2015 11:58 PM
