Quick t5 question
Old Jun 15, 2008 | 01:27 PM
89TXIroc's Avatar
Car: 89 IROC 5.7
Engine: 357
Quick t5 question
will the t5 from my 89 v8 work on my brother's 98 v6 firebird?
any differences?
Old Jun 18, 2008 | 08:14 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: Quick t5 question
No it won't fit,the bellhousing is different.
Old Jun 19, 2008 | 12:03 AM
89TXIroc's Avatar
Car: 89 IROC 5.7
Engine: 357
he has the v6 bellhousing from his t5, i was going to send him an upgraded unit because he blew his. are input and output shafts the same?
Old Jun 19, 2008 | 01:17 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
No, the splines are different on the input shaft. You can do a search and find out the difference, but I think V8's require 28 spline shaft and V6 less, maybe 26 spline shaft.
Old Jun 19, 2008 | 02:53 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
any differences?
It will not be a direct fit because the input shaft on the V6 is about .5" longer than the 1988-92 V8 cars.
See: https://www.thirdgen.org/forums/tran...ything-we.html
Old Jun 19, 2008 | 04:08 PM
Kevin84Z28's Avatar
Like I said, This is a quote from the above link "The T5 offered in V6 engines has a different bellhousing to match the V6, as well as a 10 spline input shaft, compared to the V8's 27 spline input shaft."
So it's more of a problem than just being .5" longer. The splines wont match up.
Old Jun 21, 2008 | 02:52 PM
dyed's Avatar
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
Use the v8 clutch disc, 26 splines (v6 is 14) and just use whatever pressure plate you have. The clutch is interchangeable other than the clutch disk. As for the bellhousing, you may be able to shorten the v6 bellhousing a bit and get it to work.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
buckeyecelt
Sep 24, 2015 05:50 AM
corey8084
Sep 17, 2015 02:56 PM
