trans won't kickdown
Old Jun 20, 2008 | 03:09 AM
arick793's Avatar
I have an 87 Camaro with a 305/ 700R4. The 700 has MD8 stamped on the side. Anyway, I bought the car with a blown engine, dropped in a rebuilt 305 and it drove fine for about a week, then it wouldnt kickdown when I floored it. It shifts at like 1500 RPM's and they're real soft. It only downshifts when it slows down. I tried adjusting the TV cable, but it shifts the same no matter where the cable is adjusted, even disconnected. I readjusted the TV cable, and hooked a pressure gauge up to the diagnostic port on the tranny, and all of the pressures were in correct operating range for minimum TV or something like that. I couldn't check maximum TV because I was working by myself. Any ideas? A friend of mine thinks one of the check ball in the valve body is stuck or missing. When I dropped the pan last week, there were a lot of real fine metal shavings (not big pieces, just grey gunk stuck to the pan and magnet, this was with around 200 miles of driving on fresh fluid/filter). Any ideas?
Old Jun 21, 2008 | 04:25 PM
arick793's Avatar
Re: trans won't kickdown
No one has any ideas?
Old Jun 21, 2008 | 04:41 PM
performabuilt's Avatar
Sounds like low line caused by a stuck TV valve or loose cable and now a bad trans likely I have seen the 700r4 burn up in as litle as 10 miles with either of these conditions
camaro11j
Sep 19, 2018 08:49 AM
Derick15
Sep 17, 2016 05:28 PM
theurge
Aug 21, 2015 12:46 PM
justin57
Aug 20, 2015 07:05 PM
Hello, Michael
Aug 20, 2015 03:19 PM
