Took master cylinder out, now cant get it back in
Old Jun 16, 2008 | 09:22 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
The problem seems to be the fact that even with the bleeder valve open on the slave cylinder, I cannot for the life of me get the rod in the master cylinder to stay down in the cylinder itself. Is it supposed to be spring loaded or something? I know when I bought the new slave cylinder a few years ago it was basically zip-tied down so the rod would not pop out. Is this the same for the master cylinder, or do I need to buy a new one now?
Old Jun 16, 2008 | 09:34 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: Took master cylinder out, now cant get it back in
which are you talking about the slave cylinder or the master cylinder.
in your question you describe both...
Old Jun 16, 2008 | 10:31 PM
spills's Avatar
Car: 89 RS
sorry, the problem is with the clutch master cylinder. I mention the slave because I replaced that a year or so ago, and when I bought it it seemed like it was spring loaded or something to that effect, it was basically zip tied down. I was wondering if the master cylinder was the same way. I can push the master cylinder rod in, but as soon as I let off it pops right back out. Im trying to figure out if this is normal, and if it is how do I re-install the master?
Old Jun 17, 2008 | 02:58 AM
89TXIroc's Avatar
Car: 89 IROC 5.7
Engine: 357
Yes this is normal, just bolt it back down and connect it to your pedal, should be fine from there :-)
Old Jun 17, 2008 | 05:13 PM
Simply-305's Avatar
make sure you bench bleed the master cylinder before you install it . or you will sit there for ever pumping your brake pedal.
and yes that is normal.
Old Jun 17, 2008 | 09:15 PM
spills's Avatar
Car: 89 RS
Ive always had a friend help me when it came to hydraulics, so Im sort of a novice at this. I know bench bleed means getting all the air out of the lines before installation, but how?
I had one guy tell me years ago that (at least for third gens) I could install the master/slave cylinders, pour in as much fluid as the resevoir would hold, and check it in about a day. Poor and inefficient way I know, but the car's a weekend warrior, and I only have time to work on the weekends so im not in any rush. Ever heard of this technique?
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
