why is my t5 whining from 1st to third gear?
when i did the swap the guy at advance auto parts said to use dexIII .i added that. i don't remember if it whined when i first drove it. but it started to bother me and one day i say tranny fluid on the ground. so i checked it, it was low and refilled but this time i added lucas trying to quiet the noise. also i don't have the interior installed , just the seats, no carpet or insulation. could that be why i hear mean it always makes that noise but i have nothing to block the sound. or did i burn it up when it ran low. any suggestions?
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
Re: why is my t5 whining from 1st to third gear?
Is it a WC or NWC? My WC has some whine to it in the first couple gears (and of course reverse), I thought it was normal.
I think my p.o.s. NWC also had a whine to it
also when i drive it, i drive it hard. its a stock 305 tuneport with a thermomaster chip, airbox cut, accel supercoil, 2:73 and i'm always burning the tires.
Car: Blue 89' RS
Engine: 5.7L
stock? did u change the rear? cause stock v8's came with... 3.23 gears or so. v6's came with 3.42 gears
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought NWC's used gear oil. While WC's used dexmec3.
All 5 WC t5's I have drove, whined and wouldnt go into reverse w/o grinding.
somebody changed it. i bought it like that. they must have done it for posi or something. if you look under my car its pretty rust free until u look at the rear end.
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
Being that it is a non W/C you can reduce the amount of noise it makes by switching to a 30 weight motor oil.
It will shift a little harder than with the ATF but better than if you goto a 90 wieght.
Avoid using synthetic fluid in the non W/C, shift quality will suffer over time.
Car: '89 Trans Am
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Not sure if there is any truth to this, but:
someone (mustang guy) told me that the T5's use more straight cut gears for the low gears, and helical cut gears for 4th and 5th. My WCT5 does this also, very audible, with the proper ATF.
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
All 5 WC t5's I have drove, whined and wouldnt go into reverse w/o grinding.[/quote]
To stop the grinding, try shiffting to 2nd first then shifft it into reverse.
Car: 92 Camaro RS
Engine: lO3
My nearly stock '92 RS has some transmission whine. I only notice it with the radio off and the windows up in lower gear. Also, reverse is non-synchro, so "first then reverse"
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I always go 5th to reverse, so its just straight down. Amazing the things we learn as we drive these cars.
Oh, and mine whines in 1st-3rd as well.
Max,
Engine: 350 S-TPI
Ive tryed putting into all sorts of gears, then into reverse. Still seems to grind. I have best luck with 5th to R. But still does a quick grind noise.
Car: 1985 TA
Engine: 350 crate w/bunches of goodies
Axle/Gears: Yep.. it's got 'em.
Might be just plain dumb, but I like the whine!
Car: 91 RS
Haha.......wining. Yep just some Chardonnay. No bitch slaps on spelling...haha. You would love straight cut gears if you like gear wine.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
