700r4 swapped with a th350
Old Jul 17, 2008 | 12:26 PM
tncamaro's Avatar
i am swapping in a th350 im my 85 z28. when i put the crossmember back in will i have to drill holes and move the crossmember. if so how would i go about mounting it in the new holes. this is my first camaro project.
Old Jul 17, 2008 | 01:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 swapped with a th350
You can get an aftermarket crossmember that will mount to your existing holes.
Old Jul 17, 2008 | 06:59 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
If you have $500 to spend get a conversion crossmember from Spohn.net.
If you would rather spend about $125 get the B+M torque arm relocation kit and it comes with an extension for the T-350 trans mount bolts. You will need this anyway to relocate the torque arm on the the t-350 shaft.
You should search the topic there is a lot of info already.
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
C409
Sep 1, 2015 03:42 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
