Speedometer Gear question
Old Jun 24, 2008 | 10:39 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I have a cable driven speedo, which has been giving me hell over the past few weeks, leaking, sheared gearshaft (speedo cable won't turn). Can I convert my speedo gear to an electronic one? I know I need to change my speedometer itself, but can I buy like a conversion where there will be no cable anymore?
I want to do this because I can hardly find any speedometer gear housing parts, and I know if I change to electronic, I don't need a cable to replace, I won't have a sheared gearshaft anymore, and it will stop the leaking.
Please let me know what kind/brand is best, and where to buy one.
Thanks,
- Justin
Old Jun 25, 2008 | 01:43 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Speedometer Gear question
speedo gear parts
...in case you wanna repair what you have or if you want to take the shotgun approach, patc has just about everything you need. i've ordered lots of little parts from them, gtg.
the speedo stuff is towards the bottom...
Old Jun 25, 2008 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the electronic has a gear (which could shear) along with a sleeve and o-ring (which could leak). I don't see how swapping would be a benefit.
Here's food for thought:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Jun 25, 2008 | 08:03 AM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
In the long run, my biggest problem is the cable. The first one was the original 89 two-piece cable that ripped in half, the another incident, my fault, I didn't tuck it up properly, and it melted against my headers etc...
So, would it be worth my effort, time and money to convert to electronic speedometer gear?
The stripped gearshaft was cause because of the cable metling and freezing up. With the electronic, there is no cable to melt and get stuck. And as for leaking, well, that just comes with anything that deal with fluids. I, personally think it is good to convert to electronic, but just wanting ideas.
Thanks!
Old Jun 25, 2008 | 08:59 AM
JamesC's Avatar
Not for me personally, but then I haven't experienced your problems.
JamesC
Old Jun 29, 2008 | 08:15 AM
Pat Hall's Avatar
I can't think of any cheap or easy way to convert to electric off the top of my head. Besides that, the electric unit still goes in the same hole in the tailshaft housing, so they're just as prone to leakage. Sounds like you just had some bad luck with the way you had the cable routed. All the parts you need to fix your mechanical setup properly are cheap and very easy to come by. I'd just suggest getting the new parts you need, and being more careful about how you route the new cable. I've seen lots of guys have problems with the electric ones too, so I really can't say it'd be a worthwhile improvement over what you've got now.
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
