T5 slips out of reverse
Old Jun 25, 2008 | 09:59 AM
camaro8811's Avatar
i may have an opportunty at a complete t5 set up. the tranny sometimes slips out of reverse. how do you fix this, and is it a big deal? he told me to just apply some pressure to the shifter which, to me, seems like an easy fix.
Old Jun 25, 2008 | 02:00 PM
camaro8811's Avatar
Re: T5 slips out of reverse
anyone?
Old Jun 25, 2008 | 02:41 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Transmission: 5 Speed
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
Could be the 1/2 slider (the reverse gear is on the outside of it)
Could be the reverse idler
Could be the shifter bushing/selector parts in the tail not allowing it to go all the way in.
If it is ok in all the other gears and is quiet it should be a cheeper fix
I can help you with parts if you need any
Old Jun 25, 2008 | 03:04 PM
camaro8811's Avatar
my question is: is it okay the way it is? if i just hold it in reverse will i be fine?
Old Jun 25, 2008 | 04:10 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
It should be ok for a while that way, it will speed up the wear on the reverse fork but unless you plan on spending a lot of time in reverse it will take a while to hurt it.
Veaceonee
Sep 29, 2016 08:15 PM
jrdturbo
Mar 31, 2016 02:58 PM
camaronils
Sep 20, 2015 02:57 PM
84redta
Sep 19, 2015 09:58 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
