V6 WCT5-to-V8 WCT5...
Old Jun 25, 2008 | 04:08 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
If i was to get a world class T5 for a 3.4L v6 could i just change the case and put all the internals (gears, etc...) inside a V8 style case? would it work?
Old Jun 25, 2008 | 04:21 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
Axle/Gears: 7.5" 10 bolt, 4.10, torsen posi
Re: V6 WCT5-to-V8 WCT5...
The other way around, the v6 case will work on the v8 but not the internals.
The spline count and length of the input, 2nd gear, 3rd gear, and cluster are not interchangeable between v6 and v8 and would have to be replaced to make a v6 useable behind the v8.
Old Jun 25, 2008 | 04:30 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
I am going to get the Super T5 kit, so those will be changed with he kit... i just ask because the v6 trannies are cheaper, and easier to find than v8 wc t5s...but if i got the gears, mainshaft, cluster, etc...would i be able to change put them into a v8 case or are the shift rails and everything else different too?
Old Jun 25, 2008 | 04:49 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
All the 88-92 W/C T5's use the same parts other than the input, cluster, 2nd and 3rd gears. The 5th gears are also different between the v6 & v8 but should interchange. 93-95 would also work if you also change the 1st gear. You just have to match the gear set to the motor.
The case, tail, mainshaft, synchronizers, forks and rails are all the same.
Old Jun 25, 2008 | 06:36 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
i tought the case was different since it has the 60 degree v6 bellhousing pattern... but if i was to get the super t5 kit for that trans it would work with a v8? without having to change the case?
Old Jun 25, 2008 | 09:30 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
not true, the '93 and up t-5 has a different bolt pattern for the bell housing to case than the earlier ones do.
Old Jun 26, 2008 | 12:37 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
so i would have to change the case as well? would all the parts tuck nicely into the V8 WC style case? it is a v6 WC trans from a 1994 3.4L Camaro...
Old Jun 26, 2008 | 02:32 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Will it work?
Old Jun 26, 2008 | 04:18 PM
iroc_zz's Avatar
Car: 1985 IROC-Z
Engine: 305 H.O.
87zjeff is right, my bad, the case did change in 93 so you would need to use the 88-92 case to make it work
Old Jun 26, 2008 | 05:45 PM
87zjeff's Avatar
Will it work?
as long as it is a w/c v-8 case it should.
90FormulaWS6
Mar 26, 2005 08:21 PM
