no overdrive
Old Jun 26, 2008 | 02:52 PM
gicamaro's Avatar
Car: 86 iroc-z
Engine: 87 l98 383
no overdrive
Alright here's the situation. I have an 86 iroc with a 350 swap on a 700r4. my original problem was i could only go into first and reverse. after looking on the forums i found people had the same issue i had (only had reverse and first) so i temporarily replaced the governor with an 8 dollar junk yard governor i got out of another 86 with a carbed 305.
Now it shifts out of first into second like it used to, has a slight slip when it goes into drive and won't go into overdrive at all. now my question is would this be due to the governor or do you think it is something else? thanks for your time!
note: the tv cable is at the proper adjustment, and i've even tried other adjustments and there is no change.
Old Jun 28, 2008 | 01:38 PM
gicamaro's Avatar
Car: 86 iroc-z
Engine: 87 l98 383
Re: no overdrive
anyone????
Old Jul 1, 2008 | 09:16 PM
andersond's Avatar
Car: 83 Camaro Z28 (82K miles)
Engine: tired 305!
Axle/Gears: Stock Posi
Re: no overdrive
before giving up on the tranny all together...service it completely ( if you havent already), clean out all the ports in the tranny, and then give it some time to break in....
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
