T5 Swap - Why new master?
Old Jun 26, 2008 | 11:15 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I will be doing a T5 swap soon, and am running over my checklist. I've read that you need a new master cylinder, but have had no luck in finding out why? Someone said you can use the same one from the auto car, that you only have to mount the slave cylinder resevoir onto it. So does anyone know why you need a new master for the T5 swap?
Old Jun 27, 2008 | 10:03 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: T5 Swap - Why new master?
your brake master cyl should be just fine. You will need a clutch master cyl to activate the clutch slave cyl. The clutch fluid reservoir attaches to a bracket that in turn is bolted to the drivers side of the brake master cyl.
Old Jun 29, 2008 | 10:47 PM
Shift06's Avatar
Sorry I am stupid. I was completely forgetting about the clutch master. LMAO sorry.
formula1lle
Jan 29, 2016 10:56 AM
LittleFranks
Sep 17, 2015 12:22 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
