busted first 10-bolt
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
well i think i broke my first 10-bolt lol. got the 82 running really good well i took it out and wound it out to 6500 one good time and shifted to second well when it hit i broke an exhaust hanger so i pulled over and fixed it went to take off and was turning and the rear would clunk/click and hop was fine going straight but when i turn it will do that i got on it one time going striaght and it did it. any idea as to what i broke?
Re: busted first 10-bolt
well hopefully i can in the morning but its like quarter after 1 in the morning and raining lol only problem is now it will be awhile till i get her back on the road since we just moved ect ect.
I dunno I am still learning myself but I am pretty sure your asking for trouble at 6500rpm, But who knows maybe i am just babying my motor i shift at 4 or 5000rpm and it goes like snot.
i pulled the cover and i found pices of spider gears laying in the bottom. im going to jack it up and take a better look tonight when i get off of work
Car: RS
Axle/Gears: 9" for the ladies
Spider gears are very common to break in them. Although you wouldn't know it by the people on here.
They think all the 10-bolts issues are soley because of the 7.5" ring gear.
on the piece i pulled out i could see stress cracks in it and im sure that the added traction i got from the new tires didnt help it any. for street driving i went from dryrotted 235/60-15 hoosiers that would spin for 5+ft when i hit second to new 275/40-17 kuhmo escta supra tires aired down a lil they will just barely bark when i hit second. well im debating on what to do i know i want to upgrade to 4.11's but since the move im kinda lack of funds for now so i want to try and put it back together so i can run it until i get a better stronger rear built. ive never really messed with rear gears much but i have faith in myself lol if i cant do it ive got many friends that build trucks that are always replacing gears and broken parts. what all is involved with replacing spider gears and getting it ok to drive for awhile?
Hey, if it's just your spider gears that are messed up, and the carrier itself is still ok, I can hook you up for cheap. I just threw away an open carrier that was no good, but I kept all 4 spider gears, thrust washers, and the center pin, since there was nothing wrong with them. New spider gear sets are kinda expensive. If you're interested, feel free to shoot me a PM.
weired part is i pulled the cover and no posi ok but every time i took off hard or did a burnout it always spun both tires. maybe a sign that it was goin? i know on the spider gears it looks like they have been rubbing hard between the gears for awhile. oh ad it does have 3.42's so im asuming it has been into before. i looked on the option chart for all the year thirdgens and it doesnt show that a lg4 auto car would come with 3.42's stock.
While it's probably not impossible that it got 3.42's stock, it's highly unlikely. I'm betting the original ratio was probably either 2.73 or maybe 3.08. If it was a L69 HO car, 3.23 or 3.42 would be more of a possibility. I pulled a set of factory 3.73's out of an 85 L69, 5 speed, Z/28 car at the junkyard a couple of years ago. It also had the crappy Eaton Gov-Loc posi carrier.
yea on the charts it says that 2.73 or 3.08 came in the non l69 cars. i had a friend that had a 84 5spd l69 and it had 3.73 my 86 lg4 has 2.73
Don't feel bad dude. My 89 TBI car was cursed with 2.73's too originally. I'd have to say changing the rear gears and adding a good 3" exhaust system have been the biggest/most noticeable improvements I've done so far. My next major project is going to be putting a 5 speed manual trans in. I keep putting that off since it's nice to be able to drink my big mug of coffee in the mornings without having to shift.
lol well the 86 is sitting missing motor and tranny now awaiting ls1 t56 swap and a 4.11 rear. next few mods for the 82 will be a t56 and a stronger rear when money comes along. having only three formard gears gets annoying since the car is very loud
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
UltRoadWarrior9
Sep 2, 2015 08:24 PM
