How much fluid?
Old Jul 2, 2008 | 10:25 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
How much fluid?
I will be changing my tranny pan gasket soon and I would like to know how much fluid I will need to put back in it, I don't want to overfill. It's a 700r4 and the TC wont be drained, just a simple gasket and filter replace.
Old Jul 2, 2008 | 11:52 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: How much fluid?
Per shop manual. Pan removal=10.0 pts.(4.7 liters) Fluid level should be to FULL mark with trans fluid at normal operating temp.(200F). With fluid at room temp.,(70F) level will be between the two dimples on the dipstick.
Old Jul 2, 2008 | 01:29 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: How much fluid?
Old Jul 2, 2008 | 01:53 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: How much fluid?
yeah expect around 5 qrts. put in 3 or 4 then start checking.
Old Jul 2, 2008 | 03:13 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: How much fluid?
If at all possible you should drain the torque converter also. It makes sense if your going to change the fluids, why not change all of it instead of just some?
Old Jul 3, 2008 | 04:57 PM
3rdgenmaro's Avatar
Car: 88 IROC
Re: How much fluid?
he is only replacing a gasket. not pulling the transmission
Old Jul 3, 2008 | 08:08 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: How much fluid?
I changed it yesterday, and yeah I had to because the gasket was leaking. Actually, I got under there discovered quite a few bolts that weren't even tight . Anyways, you guys were right, it took about 4.5 quarts. I used MaxLife ATF since the car has 164k miles on it. I do have a pump so I can drain the fluid without dropping the pan. I'll let it go for a little while and then I will change it again with the pump.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
