No shifting from 2nd to 3rd at full throttle
Old Jul 3, 2008 | 07:41 PM
ciar623's Avatar
Car: 1986 Z28
Engine: 355
Axle/Gears: open 2.73's
I recently took my Z/28 to the local dragstrip and took it for a couple passes. The car never made it over 82 mph and the fastest tme was 16 sec. So I said something to my brotherinlaw and he said it sounded like the car was never getting out of 2nd gear. I then took the car on the highway and floored it, it shifted fine out of first and at around 75 mph or so it started to red line at 5500 and I kept on it only too let off at 85 when the rpm's where at almost 7000. As i let off the car shifted immediately into third. I did it again in the overdrive setting on the shifter and the same thing happened. Under normal driving it shifts through all the gears with no problem and is very strong. Any suggestions will be greatly appreciated and thanks in advance, Mike
the tranny is the 700r4 w/stock converter
Old Jul 3, 2008 | 07:48 PM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
Re: No shifting from 2nd to 3rd at full throttle
make sure that cable that goes from the tranny to throttle linkage is working properly
Old Jul 3, 2008 | 08:00 PM
ciar623's Avatar
Car: 1986 Z28
Engine: 355
Under normal driving conditions it shifts properly through all 4 gears.
Also if I am driving on the highway at anything over 80mph in 4th gear and I floor it it will shift into second and buries the tach needle.
Old Jul 3, 2008 | 08:34 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Make sure the valve body and governor are "matched," I recently had this problem and a governor swap corrected the problem. Call Dana (ProBuilt Automatics) @ (909) 795-1876 to get some (THE BEST) advice. -Bill
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
