ATTN: Pro Built Automatics
Old Sep 13, 2000 | 11:36 AM
kwikgta's Avatar
I emailed you over the weekend about purchasinag a stage 3 rebuild kit for my 700r4,I haven,t heard anything back.Did you reieve my email?
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
84 TA NV
Sep 6, 2015 08:02 PM
