corvette servo help????
Old Sep 12, 2000 | 07:40 AM
My84Z's Avatar
what years do you use them for? what do they do? and how do you put them in??? thanks
Old Sep 12, 2000 | 12:15 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I'm not sure what years (I think '85-'91), I got mine from a friend who converted to a T56. He sold me his, that he purchased from a GM dealer. Appereantly they increase line pressure for the 2-3 shift (IIRC), but I have felt a tremendous shift improvement on the 1-2 shift. Even at 1/4 throttle my tires (though very used ) chirp going into second. As for installing it, you must tilt the rear of the trans down (remove anything holding it up) or if it's out, it will be easier. First you pull out the snap ring, use two flat screw drivers and push in the cover to relieve the snap ring pressure. Then remove the cover, it will be hard to pull out because of the oil seal ring on the cover. If you damaged it, most tranny places have one for cheap (I don't know $, because where I went he flat out gave it to me for free ). Note how the assembly comes out and install the 'vette servo in a likewise arrangement. Install the ring seal (if damaged/removed) and push in the cover. Install the snap ring and your done. Now install the trans and check the fluid level. Have fun.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited September 12, 2000).]
Old Sep 12, 2000 | 02:14 PM
89ProchargedROC's Avatar
You want an even better servo that the vette? i work at a trans shop in chicago and sometimes, upon request, we use fairbanks servos. WOW! they advertise 80% more area than even a corvette servo. Boy, talk about neck snapping.
Old Sep 12, 2000 | 04:48 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Here are the three part #'s:
8642079 Corvette Servo Piston
8673039 Corvette Servo Housing
8647351 Corvette Servo O-ring
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Sep 13, 2000 | 06:53 AM
Pro Built Automatics's Avatar
In our 10 second 700R4's we DO NOT use the Fairbanks servo, it is an overkill in all but stock applications, even then I question it. When everything is set up right, you don't need it, the Corvette Servo will work just fine.
Glad Too Help!!!
Old Sep 13, 2000 | 11:24 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
now you would be in the tail shaft oof the tranny to do this? i am curious because i too want to put in a corvette servo, but didnt get suffcient info on how to do it or where it was located in the tranny...
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Old Sep 13, 2000 | 11:51 AM
MRZ28HO's Avatar
Engine: was: L69
IIRC it is located above the trans pan next to the TV cable on the passenger side. It is about 4"-5" in diameter and the top portion angles slightly in to the trans. It also has a hex extrusion on the center, about 1" in size.
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
