adaptor for use of T56 on T5 bell housing
Old Sep 12, 2000 | 10:48 AM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
GM sells a T56 trans kit that comes with a drilled plate that allows a T56 to mount to a T5 bell housing, so the bell housing, clutch, etc doesn't have to be changed. Does anyone know if they sell the adaptor plate seperate or can I only get it in the kit? My friend sells T56's for $1500 with viper internals.
1986 CAMARO Z28 -> 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, reinforced LCA's, Subframes connectors, front LCA poly bushings, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.16@ 107.1MPH Next mods-> Lowering springs(have not installed yet), adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 12, 2000 | 11:41 AM
SteveSpohn's Avatar
I'd ask the guys over at http://www.sallee-chevrolet.com
They're probably the largest dealer of the Borg-Warner aftermarket T-56 transmissions.
Just so you know, this does require a different transmission crossmmeber then if you are swapping in a 4Gen T-56/Bellhousing. Using the adapter plate and the T-5 bellhousing puts the transmission mount 1.9" further to the rear of the car.
We now have a kit for this T-56 swap as well. Good luck.
Steve
Spohn Performance, Inc. - F-Body Suspension Specialists
Old Sep 12, 2000 | 11:43 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Wouldn't it require the d-shaft to be shortened too? BTW are they the same spline?
Old Sep 12, 2000 | 12:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, they say in the write-up for the kit that driveshaft has to be shorted 2", which is one of the biggest things keeping me from getting one. I dont want to cut up my aluminum driveshaft.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 13, 2000 | 12:02 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The two choices we have when swapping to the T56 is either the aftermarket version or the OEM 4th gen version, generally.
Aftermarket has a mechanical speedo drive, and steeper gears (so you 3.73's or 4.11's aren't an absolute necessity). The torque capacity is slightly lower due to the steeper first gear. Since the aftermarket T56 bolts to an adapter (that bolts to your T5 bellhousing) you can use the T5 push style clutch, but you do need to shorten both your driveshaft and torque arm. A new crossmember is required, which is different from the OEM T56 crossmember by being two inches longer.
OEM (4th gen) T56 has an electric speedo sender, and you are required to run the 4th gen pull style clutch. The driveshaft and torque arm do not need to be modified. Gear ratios are pretty tall if you are running 3.08's or 2.73's, but that 0.5 6th gear double overdrive is nice (24 mpg with bigass injectors at 85 mph) A new crossmember is required. I hope this answers a few questions.
Andris http://www.skulte.com/t56.html
Old Sep 13, 2000 | 12:19 PM
Kevin91Z's Avatar
Andris, your link wasnt found. I think it needs a capital T in t56.
http://www.skulte.com/T56.html
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
topteam54
Oct 6, 2015 12:21 AM
sreZ28
Aug 14, 2015 07:48 PM
5speed4life
Apr 2, 2004 11:24 AM
