Tranny or somthing else?
Old Sep 14, 2000 | 12:28 AM
JayZ28's Avatar
I just got my camaro back after having a tranny rebuild (700r4). The problem is it won't shift into third until like 4000-4500 rpms and 4'th just ain't happening.
Is it a bad rebuild or is my timing screwed up or my torque converter? whats the deal here?
Jay
speed is a good thing,
more speed is a better thing
Old Sep 14, 2000 | 09:59 PM
jason86/2.8's Avatar
On the drive home after having mine rebuilt I had the same problem. To get it into 4th. I just floored it down, let it hang in 3rd, shifted from OD to D and the back to OD and I got it into 4th. When I got home I was pretty pissed b/c I thought I got screwed on the rebuild, but I took it back out after a few hours and it ran thru the gears perfectly and I haven't had a problem since (knock on wood) and that's been 2,300 miles. Good luck, and I hope everything works out w/ your trans.
1986 Berlinetta, 2.8L, newly rebuilt 700R4, 3.42 Posi. 127,000 miles and counting.
I've come to realize that I'm gonna have this car till it pukes for good, b/c I'll never be able to bring myself to sell it.
Old Sep 15, 2000 | 12:16 AM
MrJ's Avatar
MrJ
Could be a few things. A bad governor, a bad TV cable, or a misadjusted TV cable. A bad/misadjusted TV cable could keep your tranny from building up enough line pressure to make a shift at the correct RPM. A bad governor could screw up your shift points, making it shift early or late. If I were you, I'd look at the TV cable first.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old Sep 15, 2000 | 04:25 PM
nickd's Avatar
I would ask the shop if they went through your valve body as they should have. It is also possible there is a stuck valve.
Regardless, they should warranty thier work so I would bring the car back to them.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
dinkrdsw
Theoretical and Street Racing
Sep 11, 2015 06:58 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
