tranny lockup quest
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
tranny lockup quest
ok guys i just put a 350 in a 1984 camaro. i have an edelbrock carb, intake, and vaccum advance distributor. my question is i still have the ecm running to the trans, is that still gna work my lockup converter?
Engine: 355
Re: tranny lockup quest
so can that be y it dont wanna shift half the time? how do i make it work? y wont it work of the ecm if its still plugged in? thanks
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The computer has nothing to do at all with the shifting of the transmission.
The ECM won't lock up the torque converter, because it doesn't have any of the sensor data it needs anymore.
Engine: 355
o ok makes sense to me now is ir bad to not have it lock up?
Engine: 383 Carb
Transmission: 4L60
Having the TCC locked in 4th gear is essential to the longetivity of the transmission, especially in the earlier 700R4s.
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
I was wondering this same question. So where does the computer get the sensor data that it needs to lock it up? Is there any way of still using the computer for the TCC if your carb/HEI/etc are not computer controlled?
If not, what is this painless kit that I hear about? WHat does it do, is it necesssary and can I make one of my own? Where would be the cheapest place to get it from if it can not be made?
Engine: 383 Carb
Transmission: 4L60
The painless kit is one of several on the market that control the TCC. You can use one of them, or you can use a handful of parts and do it yourself.
Engine: 355
Well at this point I am looking for a cheap solution. So which of the kits are the cheapest?
More importantly, what do I need to do it myself?
EDIT: I found an interesting article. It says the following:
There are several major valvebody configurations. The early '82-'87 configuration had no auxiliary valvebody; the torque converter clutch (TCC) lockup function was actuated hydraulically at a set pressure without computer input. Although this makes retrofit easy into early vehicles, the first-generation valvebodies often have leaky, low-capacity 1-2 and 3-4 shift valves that produce inconsistent shift quality.
The late '87-'93 second-design valvebody solved the problems. It added an additional auxiliary valvebody to fix a Park/Drive bang/clunk problem. A new abuse valve smoothed out rock-shifting, helping cars get out of snow and mud easier. A new one-piece 1-2 shift valve improved consistency, reduced leakage, and permitted downshifting from Second to First gear at fairly high rpm. The 3-4 shift valve was redesigned to permit WOT 3-4 upshifts. B&M offers the improved WOT 3-4 upshift kit under PN 70249.
Most second-generation valvebodies have a plugged TCC hydraulic lockup port, as GM transferred TCC lockup control directly to the engine computer. The early valve can be installed in place of the port plug to permit locking up the TCC via hydraulic pressure through the '88 models. From '89-'93, the former TCC hydraulic lockup port is completely blocked off, and no valve can be retrofitted.
So I have an 87 formula, how would I know if I have the early configuration that wasnt computer controlled or the later CC version?
Engine: 383 Carb
Transmission: 4L60
I'm not sure which is the cheapest kit, you could check Summit or Jeg's.
Doing it yourself is probably the cheaper than a kit, but you'll have to do a little of your own wiring.
Engine: 355
And hey read my above post I edited it and have a question for you.
Engine: 383 Carb
Transmission: 4L60
It'll take me a little while to dig up a parts list.
All the F body applications were completely computer controlled with the ECM switching the TCC solenoid on and off to lock the TCC. The TCC valve in the valvebody doesn't do anything.
The exception is cars built for export with non-computer carb setups. They used the TCC valve with a vacuum switch to unlock the TCC under high demand.
Engine: 355
Alright man thanks alot when you find a parts list post here. In the mean time, if I want to drive the car, what precautions should I take?
Engine: 355
Just curious, why should I not cruise in 4th? I know what a torque conv is, but I guess Im not sure what it means for the TCC to lock up or why it even needs to...
And to prevent going into 4th, could I just put it into "D" instead of "OD"? Would that keep it out of 4th? If not, how else?
Engine: 383 Carb
Transmission: 4L60
At low RPM in 4th gear you've got minimum fluid flow through the cooler at the same time as shearing of the fluid in the torque converter is at a maximum, which creates a lot of heat.
Engine: 383 Carb
Transmission: 4L60
Off the top of my head, I can think of 4 kits to control the TCC:
TCI P/N 376600 $79.88
http://store.summitracing.com/partde...5&autoview=sku
Includes: 4th gear pressure switch, internal wiring harness, external wiring harness, vacuum switch.
Pros: The cheapest of the 4 kits
Cons: Probably not what you want with a high-stall converter (more on this later)
Painless Wiring P/N 60109 $159.95
Includes: 4th gear pressure switch, brake pedal switch, solenoid, internal wiring harness, external wiring harness, transmission pan gasket
Pros: Works the same as the TCI kit, more complete if you're putting a 700R4 into an application that didn't come with one originally
Cons: Expensive because it includes many parts that a thirdgen has from the factory. As with the TCI, probably not what you want with a high-stall converter
B&M P/N 70244 (Mechanical speedo) $175.95
B&M P/N 70248 (Electronic speedo) $175.95
Includes: Dash-mounted control, VSS (mechanical speedo version), external wiring harness
Pros: Only kit that allows setting of a minimum lock-up speed, easily adjustable, has a manual unlock switch, installation doesn't require dropping the pan
Cons: Most expensive kit, no feature to unlock under load, switches the hot side of the TCC circuit instead of the ground the way everyone else in the universe does which irks me to no end
Jet P/N 700211 $134.95
Includes: 4th gear pressure switch, vacuum switch, external wiring harness
Pros: Works the same as the TCI and Painless kits
Cons: More expensive than the TCI, doesn't include internal wiring harness, again probably not what you want with a high-stall converter
Homemade kit $51.36 (I'm using gmpartsdirect.com prices. Beat your local dealership parts counter up if they won't match them, or try an AC Delco dealer)
Includes:
GM P/N 14014519 Vacuum switch $31.46
GM P/N 12101914 Vacuum switch connector with pigtail $15.33
GM P/N 8642473 N.O. 4th gear pressure switch $4.57
Pros: Does everything the TCI/Painless/Jet kits do (and more with options below), get to impress the ladies (or guys) by telling them you did it all yourself
Cons: Requires a little more effort to wire it all yourself, saves you more money that you'll just spend on gas anyway so that you can enjoy how well your TCC works
Optional parts for homemade kit
GM P/N 12085533 External connector with pigtail $20.74 (don't need this if you didn't butcher your factory wiring)
GM P/N 14020691 Vacuum delay check valve $15.39 (especially recommended with high-stall converter, also works with the TCI/Painless/Jet kit)
Radio Shack P/N 275-654 Center-off SPDT toggle switch $3.99 (if you want a manual operation switch)
Alternate/optional parts for homemade kit
From http://www.transmissionhead.com/
P/N 71V 1-6 inHg adjustable vacuum switch $43.00
or
P/N 71V2 6-22 inHg adjustable vacuum switch $43.00
or
P/N 71 7 inHg fixed vacuum switch $49.00 (use with connector below)
or
P/N 71-2 4 inHg fixed vacuum switch $49.00 (use with connecor below)
P/N 71X Vacuum switch connector with pigtail $24.00 (for above fixed vacuum switches, also works with GM vacuum switches above)
P/N 71XX Vacuum switch connector without pigtail $8.00 (if you're really cheap and you don't mind crimping the pins yourself)
P/N 71W External connector with pigtail (don't need this if you didn't butcher your factory wiring)
I need to draw up a couple of wiring diagrams, but I'll try to get the details of installation up tomorrow sometime.
Includes:
or
or
or
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
Engine: 355
Apeiron thanks a lot man this is going to help me big time.
And whats the story about that TCC switch in that link that theorio1025 posted? Would that be a good temporary fix? And does it work without the ECM?
Engine: 383 Carb
Transmission: 4L60
As long as your wiring isn't hacked up, the switch on the ALDL will work without the ECM.
Engine: 355
Engine: 383 Carb
Transmission: 4L60
Locking it up manually with the switch on the ALDL would work in the meantime. Keeping it in 3rd all the time would be a waste of gas.
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Hmmm.. this is the first I have heard of this kit. Is this kit only for the folk that have the ECM and have swapped out the CC Carb?
Should this kit this also be installed for engine swaps with the 700R4? I thought having a kick down plate was the solution?
Engine: 383 Carb
Transmission: 4L60
These kits are for anyone who has removed any part of the computer-control system, which usually means carbed cars.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Correct me if im wrong but couldnt you just get a non lockup converter and not go threw all the BS wiring.
Car: 86 Trans Am
And here I thought I had everything covered *sigh*
Glad I stumbled on this post. I'll have to see if my mechanic did anything about it. I do a lot of highway driving and don't want to replace the tranny any sooner than I have to hehe.
Engine: 383 Carb
Transmission: 4L60
Engine: 383 Carb
Transmission: 4L60
Ok, to start with, a little history on how the factory did it without an ECM...
LG4s built for export weren't equipped with a computer-controlled carb. The lockup of the TCC was controlled partially hydraulically by the transmission valvebody, and partially electrically.
Inside the valvebody, for the TCC to be locked, both the converter clutch apply valve and the converter clutch shift valve needed to be in the lockup positions.
The tension of the converter clutch throttle valve spring was balanced against governor pressure to determine a minimum TCC apply speed. The minimum lockup speed could be raised or lowered by changing or altering the spring. Vehicles with an ECM controlled TCC replace the valve, spring and sleeve with fixed plugs, bypassing this function. If the valvebody of a pre-87 transmission has the holes bored, the valve and spring can be installed.
The converter clutch apply valve was controlled by the TCC solenoid. When the solenoid was energized, the apply valve would move to the lockup position.
It's not desirable to engage the TCC under load, so a vacuum switch ("Trans Conv. Switch" in the diagram above) was also used to sense engine load. At large throttle openings, vacuum would drop and the switch would open, removing +12v power from pin A of the TCC connector. This would remove power to the TCC solenoid, and the converter clutch apply valve would open and the converter would unlock.
Vacuum for the switch was taken from the same ported vacuum source as the EGR valve. A ported vacuum source has no vacuum while the throttle is closed, so the TCC was unlocked to allow closed-throttle coasting. A thermal vacuum switch was also used in the factory setup to keep vacuum from being applied to the switch until the engine coolant reaches operating temperature, the idea to allow the transmission fluid to reach operating temperature faster.
granted its a basic lock up (4th gear) instruction for, but for DIY and keeping the trans from over heating it works well enough, at least in the mean time
edit: more DIY lock-up info
http://700r4.com/tech/tcc/brake_install/diagram.shtml
http://static.summitracing.com/globa...tci-376600.pdf
http://www.73-87.com/7387garage/drivetrain/lockup.htm
Engine: 383 Carb
Transmission: 4L60
Yeah it works, the article is just intended more for people retrofitting an O/D transmission into a car that didn't originally have one, and who aren't prepared to do a little more wiring. For a thirdgen that came with a 700R4, it's better to leave the case connector alone so you can reuse some of the factory wiring.
Engine: 383 Carb
Transmission: 4L60
Simply plugging in a non-lockup converter is the same as running a lockup converter, but never having it locked up. If you're going to use a clutchless converter, you need to make a couple of hydraulic modifications to the transmission to increase flow to the cooler. It'll still run hotter than a lockup converter, and you'll still lose mileage.
Engine: 383 Carb
Transmission: 4L60
Speaking of factory wiring...
GM changed the internal wiring of the 700R4s used in thirdgens a number of times. These diagrams are what I've seen, but there may be other variations.
Aside from the export non-CCC setup, some early units used behind V8s looked like the diagram above, with a normally-closed switch to signal the ECM when the transmission was in 4th, and a "4-3 pulse" switch, which interrupted the solenoid circuit to unlock the TCC only while the transmission was in the middle of a downshift from 4th to 3rd. The 4-3 pulse switch was found to cause a flare on the downshift though, and was eliminated sometime around 1984 or 1985, as below.
Early V6 cars never received the 4-3 pulse switch, and also looked like the above. By the way, does anyone else find it amusing that they describe the 2.8L V6 as "High Perf"?
At some point after 1987 or so, GM started using a normally open 4th gear switch, and also added a temperature switch to force the TCC to lock up in 4th gear regardless of ECM input if the transmission started to overheat, as below.
Engine: 383 Carb
Transmission: 4L60
The external wiring stayed relatively constant in all years, regardless of what went on inside. Power through the brake switch on pin A, the ECM switched ground through pin D to lock the TCC, and the 4th gear switch signalled the ECM through pin B regardless of its orientation.
From the wiring diagram, you can also see how you can still lock the TCC through the ALDL, even if the ECM is removed.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 86 Trans Am
I think this info should be a sticky, lots of good info here.
Engine: 383 Carb
Transmission: 4L60
To wire your TCC for non-ECM operation, you first need to figure out which wiring configuration you have. I'm assuming that your transmission came out of a thirdgen originally. If you're working with one from another application, the wiring could look like almost anything inside, so you'll have to take the pan off to see. Be prepared to do some rewiring on your own.
If you have an earlier year model, you'll have some variation of the circuit with a N.C. 4th gear switch. If you have a later model, you may have a N.C. or N.O. switch.
You can tell the difference easily without dropping the pan by checking for continuity between pin B of the transmission case connector and ground with the engine off. If you have no continuity, you have a N.O. switch, and you can proceed without dropping the pan.
If you do have continuity, you have an N.C. switch, which needs to be replaced for an N.O. one. You'll need to drop the pan for this, but it was probably time to replace your transmission fluid and filter anyway. The position of the switch is shown on the wiring diagram, but it's easy enough to find since it's the switch with the single terminal. It just unscrews with a wrench, and the 8642473 switch threads in its place. Connect the wire from the old switch to the new one.
If you find you have a 4-3 pulse switch on your valvebody, you may choose to eliminate it, and connect the two wires that were leading to it together, or you may choose to leave it alone.
After you've replaced the switch, replace the filter, put the pan back on with a new gasket and refill the transmission. You should now have something inside the transmission that looks like the below diagram, give or take a few components, depending on what you found or decided to leave inside:
With an N.O. 4th gear switch, now you have a few options.
The minimal way to get things working now is to just put a jumper between the wires going to pins B and D (light blue and tan/black in the diagram here, your colors may vary) on the factory harness. The solenoid will still get +12v through the factory brake switch as before. When when the transmission shifts into O/D, and the solenoid will be grounded through pin D, pin B, and the switch, completing the circuit to lock the TCC. It's easy at any time to unmolest the factory harness by removing the jumper wire. The TCC will work the same as in the first article posted by whiley, except that the brake switch will unlock the TCC during braking.
This still leaves the TCC locked up during coasting. You may also find that under part throttle acceleration without enough throttle to cause a downshift, that the car feels sluggish with the TCC locked. Both of these issues may be corrected by using a vacuum switch connected to a source of ported vacuum to bridge the wires to pins B and D as shown in the diagram below. The vacuum switch will open under low ported vacuum with the throttle closed, or under part-throttle acceleration. This arrangement is identical to the operation of the TCI/Painless/Jet kit above, with the addition of the brake switch which the TCI and Jet kits don't include. If you choose to use an adjustable vacuum switch, you can vary the amount of vacuum that the switch opens to adjust the part-throttle unlock behavior.
With a vacuum switch, you may find that under certain conditions, such as driving up hills at constant speed, the TCC will cycle between locked and unlocked. This happens when the throttle is depressed to reduce vacuum enough to unlock the TCC, but then engine RPM increases slightly which increases vacuum enough to allow the TCC to lock, which then decreases engine RPM and vacuum, and so on. The effect is even more likely and more pronounced (and more distressing) when using a high-stall converter. If this happens, you can use a 14020691 vacuum delay check valve in the vacuum line to the switch. The valve allows air to move freely through it in one direction, responding immediately to decreases in vacuum, but closes down to a tiny orifice in the other direction, allowing vacuum to increase only slowly. When used in the vacuum line, the valve will cause the vacuum switch to open and unlock the TCC immediately when the throttle is opened, but will delay the closing of the switch and the relocking of the TCC by several seconds. If you find that the relocking delay isn't long enough, you can add additional valves in series. Since the vacuum delay check valve is a directional device, it does matter which direction you install it in the line. I don't remember which direction is which, but it's easy enough to tell when it's installed correctly.
Engine: 383 Carb
Transmission: 4L60
With a little creativity, one can imagine more complicated arrangements, like this one that uses a center-off SPDT toggle switch to allow manual override of the TCC operation. Flipping the switch one way allows the TCC to lock and unlock automatically. Flipping it the other way manually forces the TCC to lock. Putting the switch in the center off position manually forces the TCC to unlock. I threw an light in there to indicate when the TCC is locked, because chicks dig blinking lights.
For my own car I went one step further. I have a largeish cam and a 3500 RPM stall on the converter. In city driving the transmission will shift into 4th gear at an RPM well below the powerband of the engine. Normally the TCC would lock then, and you'd have to put your foot fairly far into it to reduce the vacuum for it to unlock. I need to fix the shift timing of the transmission to deal with this, but in the meantime I'm also using a B&M lockup kit to keep the TCC unlocked below 70 km/h. The B&M kit switches the positive side of the solenoid circuit, which normally would defeat the high-temperature lockup switch that my 93 model 4L60 has. Keeping the temperature switch working is a Good Thing, so I use a relay on the output of the B&M control to switch the ground side of the solenoid.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
