converting electronic speed sensor to manual
Old Sep 17, 2000 | 02:07 PM
ckcam310's Avatar
is there any way to convert my 91 trans. to work with the cable driven speedometer in my 89 camaro
Old Sep 17, 2000 | 09:24 PM
84FTA's Avatar
Yes. Two ways.
First, you can get an aftermarket speedometer that would run off of the new sender.
Second, although I've heard it and never done it, you can take the whole speedo gear set from the cable set up and put it into the new tranny (assuming it's a 700-R4) and then hook up as normal.
'84 Trans Am
Crate 350 - 4 bolt main, Holley 600 w/vac. secondaries now open element
T-5 - Stock with Zoom clutch and PP
1992 Trans Am
May 10, 2023 07:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
