WONT DOWN SHIFT
Old Sep 16, 2000 | 06:05 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
WONT DOWN SHIFT
I got my tranny rebuilt a year ago and when i go to pass sometimes i floor my car and my car revs up but wont get any forwared moentum then it shifyts hard then i go any ideas whait it could be...
Old Sep 17, 2000 | 11:53 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Check your fluid to see if it's burnt. Off the top of my head is sounds like your clutches are toast (the engine winds up with no increase in speed.)
The clutches are not engaging fast enough or slipping. A problem in the valve body can also cause clutches to misbahave.
Either the fluid is the best place to start. It should be a nice color red (not dark)
Old Sep 18, 2000 | 12:13 AM
FAST RS's Avatar
Fluid is fine btu the tranny shop says nothings wrong bla bla bl even tho i know there is
Old Sep 18, 2000 | 02:31 PM
wm_sorg's Avatar
You might want to try to take it to another shop to see if they have a different opinion. Otherwise, you might want to drop the pan and see what is going on in there. Is this problem consistant in all the gears? 4>3, 3>2, 2>1?
Does it slip, or race freely then grab between the downshifts? Or does it race then slip in to the lower gear?
Old Sep 18, 2000 | 03:36 PM
FAST RS's Avatar
I only happens when i floor the car to pass and it revs up but it dosnet awalys do it
Old Sep 20, 2000 | 05:51 PM
wm_sorg's Avatar
Tough call. Sounds like a sticy valve or solinoid (sp?) to me. Try to see if there is a corelation with temprature. Winter months may worsen this problem.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
