Detent cable adustment
Old Jul 10, 2008 | 12:53 AM
Stephen's Avatar
Car: 87 GTA
Loking at this... https://www.thirdgen.org/detent... Anybody got a pic of the TPI setup? I uderstand we have V6s here, but V8s are the majority. If a V6 pic was included, the V8 pic should be first, since it would be more common. TBI & TPI
I tried adjusting what I *think* is mine, but it takes like 50lbs of pressure to ALMOST press in! my thumb hurts now
Old Jul 10, 2008 | 01:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Detent cable adustment
Doesn't matter what setup it is, the cables all look the same. Yes, the button is hard to push in. Eat your spinach. ;-) The good news is you don't have to push it in far.
Old Jul 10, 2008 | 01:30 AM
Stephen's Avatar
Car: 87 GTA
Well...The arrow 'B' looks like it is pointing to a bolt head. My tab is a 'D' shaped goldish thingie, in a black plastic housing, on the opposite side. It wouldn't possibly be identified from the angle in that pic...the passenger side.
As for the difficulty level of 1 & only needing 2 hands & a brain...What if your missing 1 of the 3? C-clamp!
I used a small C-clamp to press in my tab, but then the shaft wouldn't press in. Released a little C-clamp pressure & the shaft slid right in. Used a screwdriver to prop in it place, while I released the C-clamp. Turned the throttle...click, click, click, click...I'll test it out tomorrow. The car is on ramps right now, & I wanna get under it, but don't wana halfa put it back on my ramps.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
