Pinion bearing preload
Old Sep 25, 2000 | 09:20 PM
ede's Avatar
ede
what would it hurt to run 35 inch pounds of preload? (new bearings)
ICON MOTORSPORTS
Old Sep 25, 2000 | 09:44 PM
82camaro's Avatar
Car: 82 camaro SC
I would use about half of that. But if you must use that much preload, break the bearings in easy--don't get them hot. The bearings will "wear in" and you should be fine. Also, change the fluid after the break in period because of the fine metallic particles produced as the bearing "wear in".
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
6speedIROC
16
Mar 15, 2023 08:33 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
