Bigger Gears = speedo problem?
Old Sep 24, 2000 | 10:40 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I heard that changing the gears in my car will throw my speedo off. I'm looking at upgrading my rearend gearing, but what can I do to correct the problem of the speedo?
-Mike
Old Sep 26, 2000 | 01:29 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You will need a new set of speedo gears. They are plastic and go into the tranny. About $15 for the pair and avail at any GM dealer.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Sep 26, 2000 | 03:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
New speedo gears may or may not require a new speedometer gear sleeve as well.
1984 Silver Z28, 383 cid long-rod 4 bolt SBC, ARP Bolts, 2 1/2" Cowl w/ Cold Air Induction, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Roller Tip Rockers, MSD6A Ignition, Blaster2 Coil, HEI Distributor w/ Adjustable Advance, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flowmaster Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Sep 26, 2000 | 09:59 AM
burntblues's Avatar
Car: 1989 Camaro RS
How much work is this, after I drop in the rearend gears? How time consuming and what must be done to adjust the gears in the tranny? I also heard of a unit that you can splice into the cable running from the gears to the speedo that will allow you to adjust your speedo using dip switches. Has anyone used this>?
Old Sep 26, 2000 | 11:51 PM
If you have an auto, then all you have to do is take off the tailshaft. If you have a 5sp, then you have to drop the tranny.
-Justin-
Old Sep 27, 2000 | 10:54 AM
burntblues's Avatar
Car: 1989 Camaro RS
cool, thanks!
-=-mike-=-
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
beachrodder
Aug 7, 2015 04:27 PM
