year identification for t56
Old Sep 27, 2000 | 10:53 AM
bhagg's Avatar
I am looking to swap in a t-56 to replace my t-5. It is my understanding that the 94+ t56 has a higher torque rating than the 93. Is there an easy way to identify that a t-56 has been taken out of a 94+ fbody vs. a 93? (serial numbers, codes, marks on the casting, etc.)
thanks
bill
Old Sep 27, 2000 | 12:58 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, look for the CAGS solenoid. It'll only be on 94+ T56's.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 28, 2000 | 09:51 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
What Kevin said is true, but the 94+ 1-LE T-56 also DIDN'T have a Skip Shift Solenoid. More than likely, you won't find either the 93 unit or the 1-LE unit, since they are less common. Hope I didn't confuse the issue, just want you to be aware of one more element. HTH's
EDIT: One last thing, If you come across a 93 T-56, don't disregard it, bercause they can SAFELY handle a lot more power than what the torque rating says. Look at Johnny Hunkins 93 396 LT-1 FORMULA, he is pushing over 400 RWHP and RWTQ. Also, there are many 93 Z-28's running in the low 11's with those very T-56's. The 93 T-56 is actually better geared for 3.23 and 3.42 gears.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
[This message has been edited by 88SS6SPEED (edited September 28, 2000).]
19irocz85
Aug 31, 2015 10:31 PM
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
