will t-5 hold up?
Old Sep 26, 2000 | 01:41 PM
nestz28's Avatar
will t-5 hold up?
Right now I have an '84 Z28 with the lg4 and
t-5. The 305 is starting to get tired (150,000 miles) and I was thinking of swapping in a 350, but keeping everything else the same. Will the stock t-5 hold up, or should I just look at another 305?
thanks,
kevin
Old Sep 26, 2000 | 03:11 PM
89IROCZ
Guest
Posts: n/a
The T-5 will hold up for a little while, depending on what 350 you get. If you are going to change your engine, definetly get a 350... its a waste of time to change to another 305. If anything, you should change to a 350, and then save up more money and then change the tranny to a T56. That would be ideal in my opinion. But in the long run, if you have a torquey motor in there, the T-5 wont hold up forever.
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Sep 27, 2000 | 12:29 PM
nestz28's Avatar
thanks for the reply
Old Sep 29, 2000 | 03:29 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
There are guys out there running 11's in camaro's with T-5's and I personally know a guy running 10's in a stang on a T-5. People say "they are living on borrowed time"...2 + years for both is alot of borrowed time if you ask me. I am currently building a 475-500hp small block, I am running a T-5 behind it...I will let you know
RedLeader289
May 28, 2019 01:47 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
Briandrex
Oct 5, 2015 06:20 AM
racereese
Oct 3, 2015 03:46 PM
