T5 Swap - VSS?
Old Jul 13, 2008 | 07:58 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
T5 Swap - VSS?
Ok, I bought a T5 swap and want to get everything ready before it goes in. I have a cable driven T5 and an electronic speedo '91 GTA. Just wondering what I need to swap from the cable setup to the electronic? VSS? And how does one go about getting a part number for the VSS if thats what I need?
Old Jul 14, 2008 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 Swap - VSS?
I'm unfamiliar with the 700R4 so take this info with a grain of salt. If the VSS on your auto is the same size, etc. as the T-5, simply remove the one in the manual and install the one from the auto. The stickies may provide more useful info.
JamesC
Old Jul 14, 2008 | 09:29 AM
Shift06's Avatar
Re: T5 Swap - VSS?
According to the stickies, the 700R4 is larger for some reason.
Old Jul 23, 2008 | 07:50 PM
andyiroc88's Avatar
Car: 88 IROC
Engine: Stock 91 305 TPI
Transmission: world class t-5
Axle/Gears: 95 LT1 rear 3:23's
Re: T5 Swap - VSS?
I also need some info on this. I am putting in a t-5 with a cable speedo and my car has a vss and a 91 dash. How do I get my speedo to work?
Old Jul 23, 2008 | 08:24 PM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
Re: T5 Swap - VSS?
I can tell you that you will need the speedo cable housing from a TH350 trans. The ones on the 700 R4's and 200 4R's are bigger. If you look above at the stickies it has a ton of info that may help you out about fixing a speedo setup to work. I was just checking into it myself since I will be going from my auto OD trans to a 5 speed. HTH
Old Jul 24, 2008 | 11:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: T5 Swap - VSS?
Get an electronic VSS from a 90-92 Camaro or Firebird T5 trans. Install that. Sell or trade someone the cable VSS.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
theshackle
Aug 22, 2015 06:52 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
