T56 flywheel
Old Sep 28, 2000 | 08:31 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
T56 flywheel
Will the T56 flywheel from a LT1 bolt up to a gen 1 style engine? Will 1 piece or 2 piece matter?
Old Sep 28, 2000 | 09:42 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
It will bolt up to the 1 piece seal block. Not sure about the 2 piece seal blocks. I don't see why not though
1991 Z28 - 350 TPI, T56, Centerforce Dual Friction clutch, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, no cats, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Steve Spohn adjustable torque arm and T56 crossmember
Old Sep 28, 2000 | 08:16 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The LT1 flywheel will not bolt up to a two piece seal crankshaft. The crankshaft bolt pattern was changed when the one piece rear main seal was introduced in 1986.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.91
Best 60 FT street tires 1.930
Best MPH street tires 99.29
[This message has been edited by bjankuski (edited September 28, 2000).]
Old Sep 29, 2000 | 04:18 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey lock, like mentioned before, you will need an AFTER-MARKET flywheel for that T-56 to work with your 2-piece RMS block. CENTERFORCE sells one, your 2-piece RMS crank,has a 3.58" bolt pattern and the 1-piece RMS crank has a 3.00" bolt pattern. The CENTERFORCE flywheel is about $300, and is a good unit. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Oct 1, 2000 | 10:23 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
lt1 flywheel will bolt to all one peice rms cranks but none of the 2peice as explained above
I hope!!! LOL
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
