Fly wheel resurface (how much /min Tolerance?)
Old Sep 28, 2000 | 11:51 AM
Rylos's Avatar
My fly wheel is blued and need it resurfaced. its beem resurfaced three times so far (stone Mill). Bluing keeps returning at the same locations on the fly wheel (from the clutch!) How much can you take of the fly wheel to get to Good steel again and prevent this from Occuring. (GM wants 4 bones for a new one
Machine shop does not Know ?
Old Oct 1, 2000 | 12:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Not that this will help you out any...but I poured over the tranny section in my Helms manual, and found no refernce to flywheel minimum thickness....
The only refernce to the flywheel is that if it's blued, it should be replaced.
Old Oct 2, 2000 | 06:55 AM
Rylos's Avatar
Thanks for the Info I found a flywheel
in a friends garage Thank GOD!!!
Old Oct 2, 2000 | 02:12 PM
badbird88's Avatar
I never got my right, even with it being turned. My clutch would chatter the car to death due to the flywheel and it never went away until I replaced the flywheel. I got lucky because I got the flywheel for cost from the dealer...$200. $400 is way to high I agree! My next option was the junk yard. There is a minimum tolerance thickness and they do make spacers to bring it back out so the clutch will mate with it properly but the blue spots are bad. The flywheel is probably warping when it gets heated up and nothing will fix that. Use it as a boat achor!
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Bubbajones_ya
Jul 6, 2024 08:32 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
