speedo gear
Old Jul 15, 2008 | 06:25 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
speedo gear
i am trying to recalibrate my speedo after a 3.70 swap. i have the 7 tooth drive gear and need to find a 20 tooth driven gear. i pulled my driven gear out of my t-5 and it has a metal shaft. all i can find are the all plastic ones will this still work? i've done some research and read that the ones with the metal shaft are longer and have bigger diameter end after the gear. i also read that someone tried to use a metal shaft one in a t-5 that originally used the all plastic ones and it leaked and speedo worked erratically. now i was just wondering if it will work the other way around?
Old Jul 15, 2008 | 06:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo gear
3.70? I assume you have an electronic speedo. If so, the plastic gears won't work. Check the sticky for more info.
JamesC
Old Jul 15, 2008 | 06:39 PM
Car: 85 trans am
Engine: 383 stroker
Re: speedo gear
no mechanical its an 85 ta
Old Jul 15, 2008 | 06:52 PM
JamesC's Avatar
Re: speedo gear
I'm not a TA kinda guy, but I was under the impression that the electronics didn't come along until 86 (could be late 85, I guess).
JamesC
Old Jul 15, 2008 | 06:54 PM
Car: 85 trans am
Engine: 383 stroker
Re: speedo gear
im sorry the print is mis leading it is a mechanical and you are right there wasnt elec. till 86 except the late model 85 ta's with tpi
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
