Shaft bearing?
Old Jul 15, 2008 | 09:27 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Shaft bearing?
I have a bad vibration, especially at 50 mph. It started as a litle vibration and now it's pretty bad over time. So far I've replaced...........
1. ALL bushings, front and rear with energy suspension
2. Rear axles, bearings and seals
3. Rotors, bearings and seals
4. Had driveshaft balanced and new U-joints
5. New wheels and tires
6. New shocks and struts
7. All front steering components. Centerlink, pitman arm, tie rod, etc.
I was wondering if it might be a bushing or bearing that the shaft coming out of the rear of the transmission might be bad. I pulled my driveshaft out of my 88 I-ROC and wiggled the shaft and noticed that it's not as loose as the one in my 91 with the vibrations. Has anyone had an issue like this before? When I drive down the road, the vibrations make my passenger seat shake back and fourth.
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
