Transco kit for 700R4
Old Oct 3, 2000 | 11:06 PM
Metalifann's Avatar
Has anyone installed the transco kit for a 700R4? I was thinking of installing one and wondered what your thoughts/comments on it were. Does it work well? Is it easy to install? Can it be done without dropping the tranny?
Old Oct 4, 2000 | 02:50 PM
BrianB's Avatar
It is by no means easy! I tried to install one of these in my 86 Trans Am and needless to say it has been sitting for almost two years, because I haven't wanted to fool with it again.
Old Oct 6, 2000 | 04:42 PM
rondubbs's Avatar
transgo is the best kit for the 700r4.. you can install it with the tranny in the car,,. i dont think its that hard, you just have to take your time and read the directions carefully.
Old Oct 6, 2000 | 05:47 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
I have installed a couple of Transgo, and they are not the easiest ones out there to install, but they are the best.
As long as you can read instructions and have some kind of mechanical inclination, you should be able to install the kit.
I just did a stage 3 rebuild and shift kit in my firebird with a 2800 stall Vigilante, and it is awesome!!!
I highly recommend the kit. If you aren't sure about doing it yourself, give Dana at Pro-Built a call. He is very helpful.
800-776-3288
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
http://members.aol.com/jwnolte/raven.htm
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
