How do I bleed clutch hydraulics?
Old Oct 3, 2000 | 07:59 PM
Maverick13's Avatar
A few weeks after having my clutch serviced (new fork, TOB), I'm starting to notice some stiffness in the clutch pedal, along with a noise when I press the pedal down. The noise is not metallic (which would imply more bearing, fork problems), but sounds more like one of the cylinders is sludged up. So I want to try bleeding the hydraulics, just in case the fluid is old or got gummed up during the fork install (the mechanics did the half-assed way of holding the slave together with the frame of the car rather than replacing the plastic strap).
Only problem is I don't know what steps to take. Can someone give me a simple play-by-play on how to bleed the cylinders? Thanks!
Maverick
1989 Formula 305 TPI 5-speed
Suspension mods, stock engine
Old Oct 3, 2000 | 11:46 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi,
Get under the car with someone in it. Have them slowly start pressing down of the clutch. Open the bleeder, watch fluid **** out. when they yell "bottom" close the bleeder.. tell them to go back up slow.. Repeat 3 times. check fluid. repeat 3 times. check fluid. your done.
-- Joe
Old Oct 4, 2000 | 08:39 PM
Maverick13's Avatar
Where is the bleed nipple?
Maverick
Old Oct 6, 2000 | 11:49 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
On the top of the cylinder you can let in gravitey bleed for a while just don't touch the pedal.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old May 20, 2011 | 03:12 PM
aljohnsonii's Avatar
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Re: How do I bleed clutch hydraulics?
How stiff does it have to be mine was hard and changed clutch and slave cylinder now it's really soft anyone know if it needs to be hard
Old May 20, 2011 | 03:26 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
the engine got taken out of my car, when i got in the clutch was super hard, i pressed it and i loud poping sound went of, not the clutch is free, like not hard at all, what is it?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
