How stiff is the clutch pedal suppose to be
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I have 305 89 Camaro the clutch was very stiff and I had clutch and slave cylinder went out and now the clutch is very soft still goes in gear but id like it stiffer any sugestions
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: How stiff is the clutch pedal suppose to be
I have yet to drive my car but it has a pretty soft clutch too. Im coming from a subaru with a cable clutch. Im new to hydraulic clutch systems but i suspect that its going to be a bit softer and smoother than mechanical. The only way to get a stiffer feel is go to an aftermarket clutch i would think.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i believe the stiffness mainly comes from how strong the fingers are on the pressure plate. but also a poorly bled hydrolic slave cylinder can cause soft a pedal.
Pac J
May 17, 2020 10:44 AM
Denricci22
Sep 18, 2015 09:02 AM
Night rider327
Sep 2, 2015 04:17 AM
