NEED HELP ASAP! Aluminum DS and U-Joint questions
Old Oct 6, 2000 | 06:39 PM
Blue92's Avatar
I have a 92RS and I am trying to put an Aluminum shaft in but the u-joint at the rear won't tighten in the rear end retainers. Does anybody know what could be the problem?
Old Oct 6, 2000 | 09:12 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Make sure the u-joint is perfectly centered in the Companion Flange (yoke) if the differential.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 7, 2000 | 10:27 AM
CamaroZ_85's Avatar
what do you mean they wont tighten?? check to make sure the bolt holes arent stripped...if they are, go beat the guy w/ his driveshaft
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 8, 2000 | 03:51 PM
Blue92's Avatar
Found out what was wrong. The auto parts store sold me the wrong joint. I got the right one and everything went back right
Vintageracer
Jan 10, 2020 05:33 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
