What's Overdrive?
Old Oct 8, 2000 | 06:39 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
What's Overdrive?
I have an 86' Bird (2.8) with an automatic. Is it really 4 gears or what exactly is overdrive? No one's ever explained it to me.
Old Oct 8, 2000 | 07:41 PM
CamaroMike's Avatar
Wow Jim that's a very entry level question but here goes. Overdrive is the fourth forward gear in the automatic's shift pattern. It is called overdrive because in fourth gear the engine is spinning slower than the driveshaft. Where as when in first through third the engine is rotating faster than driveshaft. Hope this helps.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Oct 8, 2000 | 07:53 PM
Ehelmsin's Avatar
The gear is set up for highway driving. It is great because it allows you to maintain a low RPM at high speed, meaning better MPG than with the other gears. But that gearing also gives you poor acceleration, which means it will eat gas worse when acellerating than the other gears.
Old Oct 8, 2000 | 07:54 PM
Car: '89 TA
Engine: LB9
Transmission: M5
You're right, VERY entry-level. There are LARGE gaps in my auto-education. Thanks a lot though, clears things up!
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
