shifting into drive problem?
I just aquired an 85 TA and when I shift into drive it hits hard, if I don't have my foot on the brake it will burn the tire... It doesn't do this shifting into reverse and shifting while driving is normal and smooth. Is this a problem? I'm usually at 800 - 1000 RPM (stand still) when this happens. Also there seems to be a little more than normal vibration while driving, could this be related and where should I start looking to resolve this? Thanks much!
Do you mean when you go from reverse to drive or park to drive??? Mine used to do that whenever I would do either of those two. It would even spin my tires with my foot on the brake. Don't know what caused it all I know is my tranny went out in May shortly after it started that. Well about 4 months after it started that. So I would shift into OD then it would jerk then I would go down to D. It was fine doing that then the tranny went. That is my experience with this problem.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
BlackphantomZ28
Apr 24, 2016 08:14 AM
