B&M Megashifter
Car: 91 Camaro z28
Engine: TPI 350
Axle/Gears: 3.23 open
B&M Megashifter
Does anybody know how to hook up the wiring for the B&M Megashifter. The neutral safety switch has 5 wires and the switch that come with the shifter has places for 4 wires. Does anybody know which wire goes where?
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: B&M Megashifter
i cant remember how i did mine but if ur using the relay they told u to use in the intructions... they one from radioshack or something... DONT! i fried 2 of them and when they go... ur stuck bc your car wont start. it also shorted when it went and melted the idicicator cable that shows way gear your in and melted it frozen in the tube... thats USLESS! love the megashifter tho,... hate the relay... ended up using a 30amp relay from a remote car starter.
Car: 91 Camaro z28
Engine: TPI 350
Re: B&M Megashifter
Here is a picture of what my megashifter came with. As you can see the two switches have places for two wires each. And these switches are to be stacked and mounted onto the megashifter so when the shifter is in different positions the the switches will be pressed and depressed and the car will know whether its in park, drive, neutral, reverse. Well, i dont know which wires from the neutral safety switch goes where. There is five wires on the neutral safety switch and four places for wires on these switches. I hope this helps, and i hope you or somebody can help me so i can get this hooked up. Thank you.
<a href="http://s130.photobucket.com/albums/p261/Brickwall316/?action=view¤t=HPIM3149.jpg" target="_blank"><img src="http://i130.photobucket.com/albums/p261/Brickwall316/HPIM3149.jpg" border="0" alt="Photobucket"></a>
i guess that diddnt work, heres the link to the photo.
http://i130.photobucket.com/albums/p...6/HPIM3149.jpg
Car: 87 TA clone
Re: B&M Megashifter
ohhh yea those are the neutral saftey switches i thought u were talking about the relay. umm... not sure i did mine like 2 yrs ago. i didnt have a prob tho i just followed the directions with the megashifter... u did get the one for the 82-92 firebird/camaro right?
jimbo
Aftermarket Product Review
Mar 14, 2001 05:35 AM
