Can you rebuild a BW 9 bolt posi?
Old Oct 5, 2000 | 10:56 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
My posi is on it's last leg, can it be done?
89 GTA 350 5-speed
(Jet hot coated) SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,B&M ripper shifter,180 stat,alston SFC,spohn LCA relocation brackets,MAT relocation kit,free mods.
G-Tech times
0-60 5.3s
E.T. 13.91@104.8MPH (2300ft)
Old Oct 6, 2000 | 11:44 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Check your e-mail.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 7, 2000 | 11:24 AM
Tony89GTA's Avatar
Car: 89 GTA
One question for you, where can I get those shims.BTW thanks for your help!
89 GTA 350 5-speed
G-Tech times
0-60 5.3s
Old Oct 7, 2000 | 04:03 PM
MY87GTA's Avatar
Can the 9 bolt be rebuilt? I have it in my 87 GTA. The best place i've found for parts is reider racing. 1-800-356-1330
Old Oct 8, 2000 | 09:36 PM
Jeffro89formula350's Avatar
I'm getting ready to pull my 3.70 gears and posi and put the stock ones back in. would anyone be interested in either of these pieces? they both have about 3000 miles on them since installed. I'll sell them for $250 each.
89 Formula 350
Rebuilt suspension, Aluminum Driveshaft, 3.70 gears
Best 1/4 mile - 15.08 bone stock.
Old Oct 9, 2000 | 09:39 PM
BLACK Z's Avatar
Car: 86 Z28
Jeff why do you want to sell them?
Old Oct 9, 2000 | 10:18 PM
I'm putting my car back the way i got it cause I'm building a 69 camaro. After it is done I'm selling my formula... if i don't canablize it for parts...
89 Formula 350
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
