SHIFTING LATE
Old Oct 12, 2000 | 02:41 PM
APCAMARO's Avatar
SHIFTING LATE
I HAVE HAD A PROBLEM WITH MY 700R4 SHIFTING WHEN I GIVE IT ALOT OF GAS. THE TRANNY HAS BEEN REBUILT AS WELL AS A SHIFT KIT INSTALLED, NONE OF THESE HAVE TAKEN CARE OF THE PROBLEM THOUGH. MY LOCAL TRANNY GUY SAID IT MIGHT BE THE GOVERNOR STUCK OR NOT WORKING PROPERLY. RIGHT NOW I HAVE THE TV CABLE SET WHERE IT SHIFTS GOOD BUT IT ISNT SET PROPERLY,WHICH I HAVE HEARD ISNT GOOD FOR IT. PLEASE HELP ME I DONT WANT TO HURT MY NEW TRANNY......
Red 87'Z-28 350 tpi
700r4 w/b&m shift cor. servo
Old Oct 12, 2000 | 08:17 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Remove the governor and adjust it until it shifts correctly. To do this you will have to buy a governor calabration kit. B&M sells this kit, it is around 30 dollars. The kit contains springs and weights that can alter your shift points. You will have to experment with it until you get it correct. It took me three tries to get it perfect.
One other note: Adjust the TV cable so that there is no slack left in the cable at full throttle. The TV cable should not be used as a tuning device, the governor is the tuning device.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
Old Oct 13, 2000 | 02:11 PM
APCAMARO's Avatar
is the governor a part that wears out , or is there a explination of why it is acting up? the b&m kit comes with directions right?
Red 87'Z-28 350 tpi
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
Numbah-1
Oct 2, 2015 08:27 AM
mfp189
Sep 27, 2015 09:25 AM
